MGCP Typical Configurations
Feb 1st, 2008
Hi, I would like to have the basic configurations for MGCP on 2851 Router in Saudi Arabia as the CP-Tone will be Brazil as the SA CP-Tone does not disconnect the signal.
pcameron Sat, 02/02/2008 - 00:06
  • Cisco Employee,
You haven't mentioned port types, but since you referenced disconnection , I think you are talking about FXO ports.
To enable tone based supervisory disconnect on the FXO ports, you will need the following :
voice-port 0/0/0
supervisory-disconnect dualtone mid-call
cptone
timeouts disconnect 3
timeouts wait-release 3
There is a cptone entry for Saudi Arabia -
CME-Switch(config-voiceport)#cptone ?
locale 2 letter ISO-3166 country code
AR Argentina IS Iceland PE Peru
AU Australia IN India PH Philippines
AT Austria ID Indonesia PL Poland
BE Belgium IE Ireland PT Portugal
BR Brazil IL Israel RU Russian Federation
CA Canada IT Italy SA Saudi Arabia
CN China JP Japan SG Singapore
CO Colombia JO Jordan SK Slovakia
C1 Custom1 KE Kenya SI Slovenia
C2 Custom2 KR Korea Republic ZA South Africa
CY Cyprus LB Lebanon ES Spain
CZ Czech Republic LU Luxembourg SE Sweden
DK Denmark MY Malaysia CH Switzerland
EG Egypt MX Mexico TW Taiwan
FI Finland NP Nepal TH Thailand
FR France NL Netherlands TR Turkey
DE Germany NZ New Zealand GB United Kingdom
GH Ghana NG Nigeria US United States
GR Greece NO Norway VE Venezuela
HK Hong Kong PK Pakistan ZW Zimbabwe
HU Hungary PA Panama
CME-Switch(config-voiceport)#cptone SA
Try this and make a call from the PSTN to the IP phone, then drop the call on the PSTN side.
It should disconnect the call after the disconnect tone plays for a few seconds.
If your hear a cycling/repeating tone, but the voice port does not disconnect, capture a wireshark trace from the voice vlan from the gateway router that has around 10 seconds of the actual disconnect tone and post it and we can analyse it and create a custom disconnect tone.
