hobbe Mon, 02/04/2008 - 07:46
  • Gold, 750 points or more
I bought a small electric energy meeter.
it only cost something like 10 USD,
so I could checkout how much electriity diffferent devices use under different loads.
it connects between the power connection cord and the well socket.
If you only want the specification values so you can aproximate the values then go to the datasheets of each type of unit you have and it tells you there.
fx:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
Table 4
good luck
