Warning message
Joseph W. Doherty Sat, 02/02/2008 - 06:09
Off the top of my head, using CBWFQ, you could define a class for each host and police or shape its traffic rate with a dedicated class. Two problems with this approach, not sure CBWFQ would support 300 classes (256 max?), and would be a problem to maintain.
e.g. (note syntax will be off)
ip access-list extended user1
permit ip host x.x.x.x any
ip access-list extended user2
class-map user1
match access-list user1
class-map user2
policy-map traffic-control
class user1
police 8000
class user2
police 10000
serial x
service policy traffic-control out
Perhaps you might consider trying to control or prioritize the different types of traffic without regard to all your specific hosts. For instance, you could limit or deprioritze p-2-p traffic such that it would have little impact to more important traffic.
class-map low-priority match-any
match protocol BitTorrent
match protocol Gnutella
match protocol Kazaa2
match protocol eDonkey
match protocol Fasttrack
match protocol Napster
class low-priority
bandwidth percent 1
serial x
Also note, you can be very effective with outbound traffic control, much less so inbound unless you can configure the router on the other side of your Internet link.
sergio.yanez.abe Fri, 12/18/2015 - 12:20
Hello everyone:
Is it possible to set a minimum and a maximum amount of bandwidth for each host or group of hosts?
I understand that policing sets the maximum.
Sergio
Joseph W. Doherty Sat, 12/19/2015 - 04:20
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes it is, if platform supports CBWFQ, just add bandwidth statements to what I posted.  (NB: only for output/egress.)
