Network clocking for T1 FR circuit...!
Hi Gurus,
I have a T1 FR circuit between my core router and a remote router. Do I need to configure "network-clock-participation wic 1" global configuration command for proper functioning of FR-T1 circuit? Moreover, what is the differance among the effects of the commands "network-clock-participation wic 1 @ global conf mode", "clock source line primary @ T1 controller config mode" and "clockrate 64000 @ DCE of FR global conf mode"........?
Also, PLL is the primary and default source of network clock in routers, what is the significance of Network clock?
Thanks Edison,
The document is pretty informative.
But what I seek is what is the difference among these commands? When should we use what command? Moreover, what will happen if i configure my routers with network clock participate command while you say that the clocking will be provided by service provider Equipment. Kindly help remove my confusion.
