WLAN disconnets frequentlly.
Feb 2nd, 2008
I have 7 AP"s with same ssid, broadcast. When the users move from one place to another, they lose the WLAN connetions, some time the users disconnect and reconnect or some time the users need to reboot the pc itself to get the WLAN connection.
I am using ACS 3.3 for authentication.
cisco AIR-AP1231G-J-K9 (C1200-K9W7-M)
System Software Filename: c1200-k9w7-tar.123-2.JA
System Software Version: 12.3(2)JA
Bootloader Version: 12.2(8)JA
What can be the problem?
Overall Rating: 5 (2 ratings)
scottmac Sat, 02/02/2008 - 07:13
What security are you using?
Are all of the APs in the same broadcast domain, or are some on different subnets?
What are the clients? (if PC's or laptops) What version of drivers and code are they running?
How close sre / how much overlap exists between the APs and their signals?
More details are usually better than no details.
Let us know and (perhaps) we can help.
Good Luck
Scott
examples20001 Sat, 02/02/2008 - 21:19
All APs are in smae briadcast domain and same subnet.
All clients are using laptops (Dell - LATITUDE)
OS: Windows XP Professional SP2
Intel(R) PROSet/Wireless software 10.1.0.3
Plig-In: Intel(R) PROSet/Wireless - 10.1.1.162
Attached file is the config details and signals overlap diagram.
examples20001 Sun, 02/03/2008 - 18:05
Network Authentication : Open
Data Encryption : WEP/CKIP
802.1x Authentication Type : LEAP
802.1x Authentication Protocol : None
Allow Fast Roaming (CCKM) : Disabled
Is their any patch for above type connections or should I need to change the config?
scottmac Sun, 02/03/2008 - 19:26
No specific patches that I'm aware of for your specific config choices.
If you have the option, I recommend moving from C-KIP to T-KIP ... CKIP is Cisco proprietary and "may not" be supported by the Intel drivers ... at least as well as TKIP which would be more standards-ish.
If your clients and AP radios support it as an option, AES would be better security than WEP, though in this case you could have TKIP run a key rotation and make it a bit more secure.
I also suggest you check the Intel Proset features / options and make sure the "Cisco Extensions" (CCX) are enabled ... I think they would be in order to support LEAP, but verify it .... I'm getting old & feeble-brained and I don't have my laptop available to check it myself.
Let us know ...
Good Luck
Scott
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
