vwic-1mft-t1 doesn't work, need help
Feb 2nd, 2008
  • Silver, 250 points or more
Hello everyone
I was trying to install this card into the NM-HDV as well as the wic slot of a 2621xm, but always got the following error message:
%E1T1_MODULE-3-INITFAILURE: Slot 1, Unit 0 initialization failure - Firmware Download
%E1T1_MODULE-3-INITFAILURE: Slot 1, Unit 0 initialization failure - FPGA & Firmware Download
I guess I have bought a bad card, but not sure, I need your opinion on this. And also, is there any chance to fix this problem besides buying a new card, like type in some CLI commands? no?
Please help. Thank you.
SSLIN
Overall Rating: 5 (1 ratings)
pcameron Sat, 02/02/2008 - 19:11
  • Cisco Employee,
These errors indicate faulty hardware - the cards have a CPU on them as well as a programmable gate array and it looks like the router was not able to get any response from them.
You need a replacement card. If you have a maintenance contract, open a TAC service request for a RMA.
CSCO10892433 Sun, 02/03/2008 - 02:45
Hi, Paul
Thank you for the good explaination. Now I'm sure that I have a bad card. Unfortunately, I don't have any kind of contract with Cisco. The only option for me is to buy another used card from ebay and hope this time I get a good, functional card. Anyway, your reply is really helpful for me. Thank you.
regards
SSLIN
