Warning message
BGP Community
Answered Question
Feb 2nd, 2008
Router#sh route-map
route-map COMMUNITY, permit, sequence 10
Match clauses:
Set clauses:
community 13172786
where this Community comming from?as i Remembere i assigned it such 201:65
2)on the Neighbors when i issue sh ip bgp community 201:65;i didn't find any.how to toubleshoot
Correct Answer by Edison Ortiz about 9 years 6 months ago
Ali,
You need to the command ip bgp-community new-format in order to have the community displayed in the format AA:NN.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hirp_r/rte_bgh1.htm#wp1074551
HTH,
__
Edison.
Overall Rating: 5 (2 ratings)
Danilo Dy Sat, 02/02/2008 - 09:02
  • Blue, 1500 points or more
You don't have a "match clauses" and "set clauses" for route-map COMMUNITY. "community 13172786" is a community number
You should have the config...
route-map COMMUNITY permit 10
match ip address 101
set community 201:65
ip access-list 101 -entries_here-
Can you post your config?
Dandy
alsayed@litani.... Sat, 02/02/2008 - 09:59
hey Dany
how you Doin?i dont need to match any ip address just i addee the rout-map to the outside neih internal route-map COMMUNITY out
but it didn't work
what now?
alsayed@litani.... Sat, 02/02/2008 - 12:55
yes Edisson
i solved it.i forgat to add to the Neight the command:
neigh X send-community
10xs edy
