02-02-2008 08:23 AM - edited 03-10-2019 03:38 PM
I am performing a migration from v2.3 to v4.1.
I am able to download a trial of both 3.0 and 4.0... but I need to upgrade the v2.3 and I don't want to do an "in place" upgrade in case something goes wrong. I want to install 2.3 on another machine, copy the DB over, and then do the upgrade.
I cannot seem to find a copy of v2.3 for Windows NT on the Cisco website. Any ideas on where I can find it?
Solved! Go to Solution.
02-02-2008 10:25 AM
Please give me your email id , I will mail it to you. Also let me know if it is 2.3.1 , 2.3.2 or .3 ?
~JG
02-02-2008 10:25 AM
~JG
02-02-2008 04:48 PM
02-04-2008 08:09 AM
It should be there in next 5 mins, check your id
~JG
02-04-2008 08:59 AM
Got it! Thanks!
02-04-2008 10:08 PM
JG,
I have run into another issue. I was able to use the v2.3 software and backup/restore my database. I then upgraded to v3.0. But now when I try to upgrade to the trial version of 4.1 (before I can backup/restore to the 4.1 Solution Engine) it tells me I must have version 3.3. I cannot find the 3.3 software on the Cisco website. Do I need to open a TAC case to obtain this software for the migration path? We already have two 4.1SE appliances in place... I just need to migrate my user/group database.
Thanks.
02-05-2008 06:03 AM
Chris,
Please mail me the serial no. for appliance and I will provide you with 3.3.3.
~JG
Do rate helpful posts
02-05-2008 08:54 AM
Thank you. I have emailed you the serial numbers from my business email account.
02-18-2008 02:32 AM
Hi, I have one similar issue.
One of our customer bought tow 4.1 ACS SE (1113) and I need to migrate user database, from existing 3.2 ACS SE(1111). These tow existing ACS SE (1111) will be remove after definitively.
I saw that it is possible to upgrade 3.2 ACS SE(1111) to 3.3 and 4.1. After that I will be able to backup user database from older ACS to newer.
I didn't find 3.3 and 4.1 upgrades (trial version) on CCO. Should I open a TAC SR ? or is it possible for me to find SE upgrades ?
Best Regards,
Samuel
02-18-2008 05:49 AM
Sam,
Please open a TAC case to get acs software and assistance with upgrade process.
~JG
DO rate helpful posts
02-19-2008 03:06 AM
Thanks for your help, I'll do that quickly.
Samuel
