HW compatibility Question
Feb 2nd, 2008
Does AIM-VOICE-30 in 3725 WIC slot support? I will not use any NM or EVM, just the integrate WIC slots
2 qty VIC-2BRI-S/T-TE
and
1 qty VIC-4FXS/DID
The following links mention general support but not btwn all three
http://www.cisco.com/en/US/prod/collateral/routers/ps282/product_data_sheet09186a008009203f.html
http://www.cisco.com/en/US/products/hw/routers/ps282/products_relevant_interfaces_and_modules.html
Paolo Bevilacqua Sat, 02/02/2008 - 10:22
Hi, good question. Not even the HW compatibility matrix mentions whic VIC are supported in the slots of the 37xx:
http://cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
However, note the features available on AIM-VOICE-30 are not up to par with the latest DSP generation, so some people prefers to use a NM-HDV instead, that has PVDM2,
pcameron Sat, 02/02/2008 - 16:21
The AIM-VOICE-30 only supports E1 or T1 interfaces that are installed in the 3725 WIC slots. It cannot be used to provide DSP resources for the FXS or BRI ports.
Refer here for more details on the capabilities of the AIM-VOICE-30 module -
http://www.cisco.com/en/US/products/hw/modules/ps3115/products_data_sheet09186a0080088753.html#wp39993
To support the combination of the BRI and FXS cards, you will need at least two voice cards such as the NM-HD-2V
http://www.cisco.com/en/US/prod/collateral/modules/ps5365/product_data_sheet0900aecd801c595e.html
