pix and port name translation on pix. can you disable?
Feb 2nd, 2008
So in access lists on a pix you can specify a port number or port name. If you do specify a number which has an associated name like 80 for www, then when you do a show run you see the name and not the number. Is there any way to turn off this automatic replacement so you only see the port numbers? It would make it easier to deal with configs with scripts if I could.
Eli Barb Mon, 02/04/2008 - 11:54
Sure would be nice I was just working with this too. How about adding this as a feature request similar to the "no names" command?
