Database Replication ACS SE 3.3.3
Answered Question
Feb 3rd, 2008
Hellow
I've got some problems with database replication with 2 ACS SE 3.3.3
On every ACS I configured the other ACS as ACS Server.
On primary I moved the secondary ACS to replication partner.
On secondary, I did Not move Primary ACS to replication partner.
Shared key is the same on both ACS..
In the log of primary: Replication send ok
In the log of secondary: Replication failed: Secret do not match !
Secrets do absolutely match !
What can be the problem ?
Remco
Correct Answer by Jagdeep Gambhir about 9 years 2 months ago
"Shared Secret Mismatch" means that the primary server key in either the primary or the secondary server does not match.
I would suggest re-entering the secret key on the primary's self entry and the primary server's entry in the secondary server.
DO NOT COPY PASTE
~JG
Do rate helpful posts
Overall Rating: 3.5 (2 ratings)
Correct Answer
Jagdeep Gambhir Mon, 02/04/2008 - 08:22
  • Red, 2250 points or more
DO NOT COPY PASTE
~JG
remco.gussen Wed, 02/06/2008 - 02:38
Updated ACS SE's to version 3.3.4 build 12 with fix 6 and checked the keys again. Right now it is working !
Remco
