ACS 3.3.3 Machine Authentication + Restriction
Feb 3rd, 2008
I'm trying to set up Machine Access Restriction.
I configured the ACS to allow PEAP Machine Authentication.
Machine Access Restriction is also set to use de <No Access> group in case one of the authentication methodes are not ok.
When computer (member of domain) boots and shows login window, the computer authenticates with computer name. Logs in ACS show successfull machine authentication.. You can even ping the wireless computer..
Then I log in with a valid user ID and password...
No access to wireless network. Log shows error code: Denied Access Due to Machine Access Restriction.
Machine authentication is ok, user authentication is ok. Why do I get a Denied Access ?
Remco
jbayuka Mon, 02/11/2008 - 07:01
  • Bronze, 100 points or more
Cisco Secure Access Control Server (ACS) Solution Engine supports many RADIUS attributes. You can enable different attribute-value (AV) pairs for IETF RADIUS and for any supported vendor. This appendix lists the standard attributes, vendor-proprietary attributes, and vendor-specific attributes supported by Cisco Secure ACS.
