FailOver problem
Feb 3rd, 2008
I have 2 Pix 525 .it works as Active/Standby .in my case the Active is the secondry and the standby is the primary Pix. we use Failover cable and stateful failover together .
the Sync/Failover is working fine but
When i configured subinterfaces on the inside of the Active pix(Secondry) and issued the write memory command on the Active ,the Syncronization failed and both of them become active .
When i removed the subinterfaces config and configured ACL or anything else the Failover process works fine.
Any Help Pls?
jojuarez Sun, 02/03/2008 - 21:37
I don't know what is the version you're running but please double-check FO configuration based on the following links:
*** For v6.x ***
*** For v7.x ***
If everything seems to be ok, remove FO config and wipe out the configuration of standby PIX. Then configure FO back and do a "wr mem" and "wr standby" in order to copy the config from active to standby PIX.
That should work
