Context Problem In ASA
Feb 3rd, 2008
Hi, This is Ridhwan. Regarding ASA 5510 I created context.
example c1 and c2 and I added all interface to inside the context (c1, c2).
but I can't get security level command and nameif, vlan. I tryed all command but not coming i am using ver 7.2.
example....
Rack01ASA1(config)#hostname Rack01ASA1
Rack01ASA1(config)# mode multiple
Security context mode: multiple
Rack01ASA1(config)# admin-context admin
Creating context 'admin'... Done. (4)
Rack01ASA1(config)# context admin
Rack01ASA1(config-ctx)# config-url flash:/admin.cfg
WARNING: Could not fetch the URL flash:/admin.cfg
INFO: Creating context with default config
INFO: Admin context will take some time to come up .... please wait.
Rack01ASA1(config-ctx)# context c1
Creating context 'c1'... Done. (5)
Rack01ASA1(config-ctx)# config-url flash:/c1.cfg
WARNING: Could not fetch the URL flash:/c1.cfg
Rack01ASA1(config-ctx)# allocate-interface e0.2
Rack01ASA1(config-ctx)# allocate-interface e0.4
Rack01ASA1(config-ctx)# allocate-interface e0.3
Rack01ASA1(config-ctx)# config-url flash:/c2.cfg
WARNING: Could not fetch the URL flash:/c2.cfg
Rack01ASA1(config-ctx)# allocate-interface eth0.5
Rack01ASA1(config-ctx)# allocate-interface eth0.4
After that I can't go inside the contect c1 or c2
I can go to inside the inderface (eth0.4 or eth0.5) but i can't get this this command (nameif, vlan,security level)
so please advice me.
Thank u so much
Bye
Ridhwan
srue Sun, 02/03/2008 - 21:28
  • Blue, 1500 points or more
assign vlans to the subinterfaces w/in the system context. then try it.
ridhwankaja Mon, 02/04/2008 - 05:41
Hello Dear,
I can't get vlan option in sub int inside, please advice other options.
Bye
Ridhwan
