02-03-2008 07:45 AM
I have one T1 circuit for TDM voice traffic. It supports in/out (can recevie call from provider and send the call to providers). How do I send the call to provider always from channel 23rd? how to config the routers?
Rgds
Solved! Go to Solution.
02-04-2008 08:44 AM
Usually providers send calls on the lowest channel. You can check that with "debug isdn q931".
However the ISDN protocol is made so that call will never collide, so you don't have to worry about.
02-03-2008 10:28 AM
Hi, by default, the router sends outgoing calls from the highest channels in descending order. So, there's nothing to configure.
02-04-2008 07:10 AM
if so, the provider sends us the call via highest channels. does it have problem? (in bound call and outbound call go to the same channel). how to avoid it?
rgds
02-04-2008 08:44 AM
