7206 E1 Module
Feb 3rd, 2008
I want to purchase E1 module that are supported with plateform
Cisco 7206VXR (NPE-G2)
I have found a module PA-MCX-2TE1 and one is
PA-VXC-2TE1+ =2 port TE1 hi-capacity enhanced voice PA
Kindly tell me which module is best.
I am confuse about these module.
Waiting for reply,
thanks in Advance.
royalblues Sun, 02/03/2008 - 09:50
It depends what you want to use the E1's for?
The PA-MCX-2TE1 is the MIX-enabled T1/E1 port adapters which provide the ability to integrate voice and data on the same T1/E1 interface without the need for an external time-division multiplexing (TDM) device.
More info here
PA-VXC-2TE1+ are enhanced digital voice port adapters offer an end-to-end interoperable voice-over-IP (VoIP) solution
More info here
