802.1x
Overall Rating: 5 (1 ratings)
royalblues Sun, 02/03/2008 - 10:45
  • Green, 3000 points or more
Ali,
Dot1x is a port authentication that restricts unauthorised clients from connecting to the line.
In additional to above commands you will need the follwoing under the interface that needs to use dot1x
interface
dot1x port-control auto
More info here
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/configuration/guide/Sw8021x.html
The commands under the consoel and VTY lines would enable aaa on these for the group. If default group is used it applies to all the lines
Narayan
royalblues Sun, 02/03/2008 - 11:32
The commands listed by you are the fallback methods for login and i dont think would be nneded for dot1x
Narayan
