No Inside Access When VPN'd Into PIX from Behind Linksys Router
Hello, everyone. I have a PIX VPN/firewall that works great for providing VPN access from behind other NAT'd firewalls (Apple AirPort, Cisco PIX), but when I try to VPN from behind a Linksys WRT54G (firmware 8.0.0.2), I can authenticate the IPSec connection, but can't see any clients on the remote network. I have VPN passthrough enabled on the Linksys, and wouldn't think it would be something in my PIX config, but thought I'd post it here and see what you all thought.
Many, thanks!
ajagadee Mon, 02/04/2008 - 13:00
  • Cisco Employee,
Can you post the output of "show crypto ipsec sa" for this specific vpn client session after you connect to the pix and not able to ping the internal network.
Also, what do you see under packet encrypts and decrypts on the client. Do you see packet being sent and not received.
Arul
** Please rate all helpful posts **
kbilbee Wed, 02/06/2008 - 19:23
I am having the same Issue. Here is a
The Packest under statistics
Encrypted: 164 and rising
Decrypted: 0
Discarded: 4
Bypassed : 97 and rising
Crypto map tag: cisco, seq num: 1, local addr: 192.168.200.253
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (169.14.133.63/255.255.255.255/0/0)
current_peer: 192.168.200.26, username: kevinbilbee
dynamic allocated peer ip: 169.14.133.63
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 79, #pkts decrypt: 79, #pkts verify: 79
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
#pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
#PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
#send errors: 0, #recv errors: 0
local crypto endpt.: 192.168.200.253, remote crypto endpt.: 192.168.200.2
path mtu 1500, ipsec overhead 58, media mtu 1500
current outbound spi: 75046F60
inbound esp sas:
spi: 0xE54F6DE0 (3847187936)
transform: esp-3des esp-md5-hmac none
in use settings ={RA, Tunnel, }
slot: 0, conn_id: 6, crypto-map: cisco
sa timing: remaining key lifetime (sec): 28740
IV size: 8 bytes
replay detection support: Y
outbound esp sas:
spi: 0x75046F60 (1963224928)
sa timing: remaining key lifetime (sec): 28739
IV size: 8 bytes
kbilbee Wed, 02/06/2008 - 19:37
I figured outmy issue it was an access-list issue. I had a typographical error.
Arrrrgggggg!!!!
