VPN Throughput 225Mb/s / # of VPNs?
Feb 3rd, 2008
Per the datasheet below Cisco states that you can up to 750 VPNs configured on an ASA 5520 with 225Mb/s throughput. What throughput can you expect as you add VPNs on the outside interface? Would it be 225Mb/s divided by the number of VPNs you put on that outside interface or can you get 225Mb/s sustained for each VPN?
Cisco ASA 5520 Adaptive Security Appliance Platform Capabilities and Capacities
Firewall Throughput
Up to 450 Mbps
Concurrent Threat Mitigation Throughput (firewall + IPS services)
• Up to 225 Mbps with AIP SSM-10
• Up to 375 Mbps with AIP SSM-20
VPN Throughput
Up to 225 Mbps
Concurrent Sessions
IPsec VPN Peers
SSL VPN Peer License Levels*
10, 25, 50, 100, 250, 500, or 750
Security Contexts*
Up to 20
4 Gigabit Ethernet ports and 1 Fast Ethernet port
Virtual Interfaces (VLANs)
VPN clustering and load balancing
High Availability
Active/Active, Active/Standby
* Separately licensed feature; includes two with base system
irisrios Fri, 02/08/2008 - 10:26
If you try establishing more than 750 VPNs , which is the maximum VPNs possible it will drop those connections. But I have not tried it practically.
