how to transfer ios image from flash disk
Answered Question
Feb 3rd, 2008
I'm working on a Cisco 2851 router which has a flash disk in the front panel. I don't know how to upgrade an ios image using this flash disk. is it the same as using TFTP server? I know how to do it with TFTP server.
Correct Answer by Richard Burts about 9 years 3 months ago
Wayne
Working with the flash disk on the 2851 is essentially like working with normal flash on other routers. The same commands (such as copy tftp flash) work here the same way that you are used to.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Sun, 02/03/2008 - 19:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Wayne
Rick
