LMS Corrupted ANI database
Feb 3rd, 2008
Version LMS 2.6, CM 4.0.6
Ani DB was corrupted and then it was cleared by perl script with key -restore. But the cleared database does'n work. In CM administration menu is no discovery start option! And when i'm starting discovery (discovery menu settings) there appear error message:
Seed Device Exception Message: Exception in connectToAni()
Seed Device Exception Message: Can not start device discovery, ANI Server may be down.
"Seed Device Exception Message: Exception in connectToAni() "
"Seed Device Exception Message: Can not start device discovery, ANI Server may be down. "
Joe Clarke Mon, 02/04/2008 - 22:56
Please post your ANIServer.log, ani.log, and NMSROOT/MDC/tomcat/logs/stdout.log files.
Joe Clarke Tue, 02/05/2008 - 23:55
It looks as though you've changed the hostname of this server. ANI is trying to establish a connection with host "cw" which is not resolvable. If you change the name of an LMS 2.6 server, you must follow all the steps at http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_common_services_software/3.0/user/guide/diagnos.html#wp1078582 .
It also appears that your server is set for a non-English locale. Your server must be running in either US English or Japanese for full support.
