QOS enabled?
Feb 4th, 2008
I was checking the QOS configuration of a switch and found this:
Switch>sh mls qos
QoS is disabled
QoS ip packet dscp rewrite is enabled
Can anyone tell me if QOS is in place or not? A show mls qos stats is showing the following:
Switch>sh mls qos interface fastEthernet 0/1 statistics
FastEthernet0/1
dscp: incoming
0 - 4 : 21693011 0 0 0 1716
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 1525566
25 - 29 : 0 78 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 11849782 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 36921584 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 2321079
25 - 29 : 0 1077 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 10928282 0 8262061 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 22016236 0 0 1525643 0
5 - 7 : 11851577 0 0
cos: outgoing
0 - 4 : 61787507 0 0 1261 4
5 - 7 : 365572 7115276 186724
Policer: Inprofile: 0 OutofProfile: 0
Overall Rating: 5 (2 ratings)
simonstoll Mon, 02/04/2008 - 00:15
If you type "mls qos" in global mode, then you switch on all qos processing. Without that command, all DSCP and or COS markings are passed through unchanged. You can check that with ethereal/wireshark.
Simon
muca Mon, 02/04/2008 - 00:27
Sorry Simon, I am pretty new to QOS.
So, does it mean that from "LAN" perpective all traffic will have a best effort basis?
I mean "LAN" because maybe QOS is enabled on the "provide" router?
simonstoll Mon, 02/04/2008 - 01:20
As long as you don't enable QOS on your switch, everything goes trough it as best effort. All markings are kept original and no special queueing based on any marking is done. Be careful in enabling QoS on your switch if your provider is using it. If you enable it without enabling some kind of trust on your ports, you will overwrite all DSCP/Precedence or COS Tags! Maby you suold ask your Provider what he is looking for.
Simon
muca Wed, 02/06/2008 - 12:51
Hi Simon,
You mentioned "All markings are kept original and no special queueing based on any marking is done" however a show mls qos interface gig1/0/1 shows packets are being marked, so I am still not sure if it's working or not.
AGACRE01>sh mls qos interface gigabitEthernet 1/0/1 stat
GigabitEthernet1/0/1
dscp: incoming
0 - 4 : 4672579 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 486139
25 - 29 : 0 111044 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 6742687 0 9241 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 4601322 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 837984
25 - 29 : 0 242 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 6736504 0 83660 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 4708520 0 0 594444 0
5 - 7 : 6742677 9241 18
cos: outgoing
0 - 4 : 12210191 0 0 189 0
5 - 7 : 62129 64128 11695
AGACRE01>
simonstoll Wed, 02/06/2008 - 23:59
You can verify it with a packet sniffer such as Ethereal/Wireshark.
Simon
