Advice need for security Track
Feb 4th, 2008
HI
IF I continue my Track in security then after complete CCSP , if I Take training CCIE (security) and CISSP then cover the security and security policy track or need another part. without CISSP , CCIE security fullfill the CISSP part ?.
Biplob
m.sir Mon, 02/04/2008 - 01:07
CCIE is purely a technical certification while CISSP is process driven. As a
CCIE, you have demonstrated technical competence in your area of expertise. CCIE is vendor based..
There are few overalapping areas (encryption, PKI theory, VPN).. I think CISSP can be helpful when you study for CCIE security written
Check this comparsion table
http://www.cramsession.com/certifications/compare-certifications.asp?cert_ids=57&cert_ids=42
M.
iqbalkhan Mon, 02/04/2008 - 03:20
HI
Its helpfull.IF I only give CCIE written then its helpfull for carrer ?
Biplob
