AIM-ATM not recognize
Feb 4th, 2008
I'm trying to configure a router in ATM IMA but I have a problem to configure the mode atm ima under the controller.
I installed the ATM IMA module on the mother board but I do a sh diag :
WIC Slot 0:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : B0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC11521VCT
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 31 35 32 31 56 43 54 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
and my version is Version 12.4(3h)
and sh ver 2 FastEthernet interfaces
2 Channelized (E1 or T1)/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Can you advice me, please.
yavuz.ozdemir Mon, 02/04/2008 - 05:25
I upgraded from 12.4(3H) to 12.4(11)T4 thinking that it might take care of the problem but now I see in the sh diag CLI
my ATM IMA module but when I do a sh ver I don't see the module AIM. And still I can't configure atm ima on the controller.
card type e1 0 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
yourname(config)#controller E1 0/0/0
yourname(config-controller)#mode ?
cas Configure CAS (Channel Associated Signal) mode
ccs Configure CCS (Common Channel Signal) mode
paolo bevilacqua Mon, 02/04/2008 - 05:30
  • Hall of Fame,
    Founding Member
Which exact IOS are you running?
You might need "SP services" or "advanced IP services" image for ATM IMA.
