default password for when the server is unreachable
Answered Question
Feb 4th, 2008
Hi I have recently configured AAA. when the server is running everything is fine but when the server is unreachable i'm locked out. How can I put a default username and password on for when the server is unreachable
Correct Answer by Richard Burts about 9 years 3 weeks ago
James
There are several ways to configure AAA so that you are not locked out if the server is not available. You can use a locally configured user name, as you suggest here, or you can use the configured line passwords.
To use a locally configured user your configuration might look something like this:
user rick password cisco
aaa authentication login default group tacacs+ local
Or to use the line passwords as a backup your config might look something like this:
aaa authentication login default group tacacs+ line
You also probably need a backup for access to privilege mode. This is usually done using the locally configured enable secret. To do this the configuration might look something like this:
aaa authentication enable default group tacacs+ enable
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Mon, 02/04/2008 - 04:41
James
Rick
