Monitoring CRC Errors at ATM 0
Feb 4th, 2008
I want to monitoring the CRC Errors that are shown in Show Interface ATM 0 using MRTG. I try to find the correspond MIB and OID that show this erros but have no success. Anyone does know wich are these MIB and OID?
Thanks.
ebreniz Fri, 02/08/2008 - 10:38
  • Silver, 250 points or more
Afaulty or failing ATM interface could also cause CRC errors. CRC errors suggest that when the Segmentation and Reassembly (SAR) reassembles the packet and checks the CRC, the calculated CRC value does not match the value in the assembled packet's CRC field.The MIBs are the ATM mib and RFC1213 MIB.
http://www.cisco.com/en/US/tech/tk39/tk48/technologies_tech_note09186a00800c93ef.shtml
ATM subinterfaces have begun to be supported from ios version 12.0(7)T onwards, you can view this URL:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/relnote/7000fam/rn7x000t.htm#xtocid2866519
