cmexport ut in LMS 3.0.1 fails
Feb 4th, 2008
in LMS 3.0.1 with CM 5.0.2 the command: cmexport ut -u user -p password -host makes the following output and the file is empty:
log4j:ERROR No appenders could be found for category (com.cisco.nm.ani.clients.u
tng.application.UTDataManager).
log4j:ERROR Please initialize the log4j system properly.
License warning message:
Username:user
ERROR DEEUTProcessor: Problem in extracting data from UT Serverjava.lang.NoSuchF
ieldException: UserName
XML Data successfully stored in file C:/PROGRA~1/CSCOpx/files\cmexport\ut\20082
4123337ut.xml
In LMS 3.0 it worked, also the l2topology export works in 3.0.1,
but the ut not
regards
Alex
Overall Rating: 5 (2 ratings)
Joe Clarke Mon, 02/04/2008 - 11:57
This is a bug. I have created a patch for it, but you will need to open a TAC service request to get it. Have your engineer contact me directly for the patch.
Martin Ermel Thu, 03/12/2009 - 03:28
What is the BugID for this one? I cannot find it in the BugTool.
Is it correct, that LMS 3.1 (CM 5.1 ) does have the patch built-in ?
