SDM problem
samtiano2001
I am trying to download a Demo of SDM to my computer but it doesn't work , what might be the problem .
Whenever I enter the username as anonymous and password as my e-mail address it doesn't doesn't work . I wonder what might cause this failure .
Richard Burts
Sam
I am not sure what demo of SDM you are trying to use or where it came from. In my experience the implementation of SDM frequently uses cisco as the user name and cisco as the password. You might give those a try. Otherwise is there any documentation that comes with the demo that might give name and password help?
Rick
Rick
Lucien Avramov
Level 10
Level 10
username cisco privilege 15 password cisco
line vty 0 4
login local
Then you are all set to use cisco / cisco to login
Make sure you have ip http-server as well
