NM-NAC + NM-WLC + ISR Deployment Scenario
Feb 4th, 2008
  • Bronze, 100 points or more
It's apparent the NM-NAC and NM-WLC can be deployed in the same ISR, at the same time, to support the use of NAC in wired and wireless scenarios.
According to the FAQs, this type of deployment MUST use PBR to direct the traffic to the untrusted interface of the NM-NAC. Is this true?
Or is it also possible to use bridging, so that wired and wireless users are Layer-2 adjacent to the NM-NAC untrusted interface, and allow the NM-NAC in Real-IP mode, to route the data out of it's trusted interface, into the ISR, which can then route the traffic onwards as necessary?
Thanks.
Cheers
Phil
