Services for 7931?
Answered Question
Feb 4th, 2008
Does the 7931 support XML Services?
Correct Answer by Paolo Bevilacqua about 8 years 11 months ago
Are you using CME?
If so, configure an ephone-template with button-layout (1 or 2). Assign template to ephone. Reset phone. Press topmost button, press 4 to access Services.
Overall Rating: 5 (1 ratings)
farmerajf Mon, 02/04/2008 - 06:00
Do you know how to invoke the services menu as the phone does not have a services key on?
Correct Answer
Paolo Bevilacqua Mon, 02/04/2008 - 06:21
Are you using CME?
