Help neded: CSS VIPs visible from servers
Answered Question
Feb 4th, 2008
I have CSS configured with two vlans. VLAN 202 (client side) and VLAN 201 (server side). I have defined virtual interface on vlan 202 that is bound to content Oracle_INFRA. Load balancing works just fine,clients can see VIP etc., but the problem is that contents VIP (10.0.18.129) needs to be visible from content servers(10.0.19.131,132). Is there any way to do this?
Config is in the attachment.
Correct Answer by Gilles Dufour about 9 years 2 months ago
You need to nat the server ip when they contact the vip in order for this to work.
The following config will just achieve this.
group client-nat
vip add 10.0.18.129
add service CRSIDM01_INFRA
add service CRSIDM02_INFRA
active
Gilles.
Overall Rating: 4.5 (3 ratings)
Correct Answer
Gilles Dufour Mon, 02/04/2008 - 06:41
  • Cisco Employee,
group client-nat
vip add 10.0.18.129
active
Gilles.
RAJINDER UPPAL Wed, 02/06/2008 - 14:56
Also if you want to mask the source IP as the VIP you can use "add destination service" vs "add service".
If you want to see the source as the VIP's IP.
FYI
Dr. Rajinder Uppal
