PPTP Issue
Feb 4th, 2008
I am getting a problem, That ,
when I am trying to access client VPN(PPTP) from my DHCP IP , I am getting Error-619, but If I am trying to access same VPN thru one to One NAT IP, then I am able to access. please tell me why I am not accessing thru DHCP IP.in my network I am using ASA5510.
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Mon, 02/04/2008 - 09:05
Please follow the examples provided on this link pertaining to PPTP and ASA version 7.x to 8.x..
if you are using PAT for outbound PPTP connections you must have pptp inspection in your global policy.. because you are using one to one NAT I suspect you do not have pptp inspection configured, your dhcp addresses are most likely PATed for outbound connections.
pixfirewall(config)#policy-map global_policy
pixfirewall(config-pmap)#class inspection_default
pixfirewall(config-pmap-c)#inspect pptp
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094a5a.shtml
Rgds
Jorge
JORGE RODRIGUEZ Wed, 02/06/2008 - 17:49
Nitin, thank you for your update and very glad your issue has been resolved. Could you mark this thread/post as issue been resolved.
Best Rgds
Jorge
