Event viewer on IPS 4200 DM
Feb 4th, 2008
Hi, i have the correct time (local) on IPS with an UTC offset positionned but on the Event Viewer windows the time of events is always in UTC time and not in local time (system time).
That is an issue or normally ?
mhellman Mon, 02/04/2008 - 12:24
  • Blue, 1500 points or more
It's a feature;-) normal. the event viewer on the sensor is not very user friendly when it comes to entering date/time ranges.
mrobert Mon, 02/04/2008 - 13:49
many thanks for your reply,
Michel
