Unity 4.2 ES132 add Prompt file question
Feb 4th, 2008
I am trying to install Unity 4.2 ES132 post install audio prompt file. I do not know the "best" way to place this file into the application. Does anyone have experience or guidance on adding system prompt files?
mrmccann Mon, 02/04/2008 - 16:02
  • Cisco Employee,
The prompts are all just files in the Windows file system. I assume you are referring to AvSubMsgPlayENU426.wav?
Just find the file on your file system (typically under \Commserver\Localize\Prompts), back it up by renaming the existing file to something else (oldAvSubMsgPlayENU426.wav). Then copy in the new prompt. The change will take effect automatically.
tgrisham Mon, 02/04/2008 - 16:14
would I need to update prompt.ini nformation as well?
my directory is:
D:\CommServer\Localize\Prompts\ENU\G711\AvSubMsgPlay
I do not see an existing file called AvSubMsgPlayENU426.wav so I'm assuming this is a new file with the
