IPCCX
Feb 4th, 2008
HI All
I have just procured CCM5.1 and got 5 free IPCCX seats that i would like to test(POC)on a Dell server before investing in the an MCS.I know this is not Supported by Cisco, but i just need this for testing Maximum two months then i will procure the MCS.
Thanks in Advance
Abdulbaseer Mohammed Mon, 02/04/2008 - 19:23
What is your Questoin?
Your installation will abort if you follow the standard procedures at least that is how for previous versions.
Good luck,
Baseer.
adam.jackman Tue, 02/05/2008 - 05:22
That is true, there are ways around it, but one it will make support from TAC difficult and may cause future problems when upgrading.
How did you purchase the CM software etc? Do you have access to a Cisco service manager or Cisco Partner who could get you access to Cisco demo facilities? It would be a safer option than trying what you are suggesting.
Adam
tmailula Tue, 02/05/2008 - 11:19
Thanks ,
Any Workaround, to avoid the installation to abort.
marijatopic Wed, 02/06/2008 - 01:10
hi,we have Comunication manager 6.0 Bussines Edition and want to install 5 seats for IPCCX we got in the bundle.we only got the LIC file for seats, no IPCCX software.as i understand we have to order the software for the dedicated server.We have 3rd-party server HP DL380G5 5150 2G EU Svr.are these SKUs for full deployment of contact centar CCX-5.0-BDL-78xx=?? And where can we check witch MCS matches our HP server?
