WS-X6516A-GBIC with 1000BaseSX operating at 50 or 62.5
Feb 4th, 2008
Dear all,
I use WS-X6516A-GBIC with 1000BaseSX GBIC
I have a general question how to find out if the GBIC (or for example an SFP GLC-SX-MM) is operating at 50/125 or 62,5/125 µm LWL cable.
I have a Cat6509
Many thanks
Juergen Fischer
andrew.burns Tue, 02/05/2008 - 05:17
  • Gold, 750 points or more
As far as I know there's no way to tell - I believe the whole reason for using SFP's is to hide this information from the switch.
If you were a real optical wizard you might be able to figure it out from the output of a "show interfaces transceiver" but I wouldn't like to bet on it...
Andrew.
