Router ok for BGP tables?
Feb 4th, 2008
What memory requirements would you suggest for a router receiving full tables? My organization currently uses a 3825 for static-routed, single-homed internet connectivity. In the next several weeks we will be preparing to multi-home by adding another ISP, and I wanted to get opinions on how much memory is enough although I doubt we will be taking the full table.
Here's partial output from a 'sho ver':
Cisco 3825 (revision 1.1) with 1009664K/38912K bytes of memory.
Is this the memory I should be concerned with regarding this project?
Thanks in advance.
/rls
Overall Rating: 4 (2 ratings)
Danilo Dy Mon, 02/04/2008 - 08:44
You need 512MB
240K+ prefixes, 3800 utilizes around 240MB and 40MB IO.
Dandy
rsamuel708 Mon, 02/04/2008 - 10:13
Dandy,
Based on the output I posted above, how much does this router have, and what commands will show me the output I'm looking for regarding memory. i.e. you say I need 512mb...will a 'sho ver' tell me this amount is present in the router?
/rls
