Change point to point into point to multi point
Feb 4th, 2008
I'm new to the UC500 and don't know how to set the voice from point to point into point to multi point, i'm using KPN euro ISDN multi point ? can some one help me out?
Paolo Bevilacqua Mon, 02/04/2008 - 09:51
By default, the ISDN BRI is set for multipoint. In this case is recommended that you use "isdn tei-negotiation preserve" under BRI interface.
If you want point-to-point, use "isdn static-tei 0".
hotrot_net Mon, 02/04/2008 - 10:10
Dear p.bevilacqua,
I do question that, i use a not multi isdn and than it's working when i do use the multi isdn it's not working.
Thanx andy
hotrot_net Mon, 02/04/2008 - 10:36
I don't know at the moment. I'm not at the location where the UC500 is placed. Didn't set SSH open for i-net at the moment so can't login remote.
Why is there a trouble with older ones?
