02-04-2008 10:36 AM - edited 03-10-2019 03:38 PM
Does anyone know what it is? I just installed ACS v 4.0 and am trying to access the admin webpage. Thanks,
Solved! Go to Solution.
02-04-2008 12:28 PM
By default there is no user name password, make sure you are connecting locally and not via RDP.
~JG
Do rate helpful posts
02-04-2008 12:28 PM
~JG
02-04-2008 12:33 PM
Use the browser on the same machine you installed ACS. http://127.0.0.1:2002
This will not require login credential
From there, create your account so that you
can log into ACS from other machines via
CCIE Security
02-04-2008 12:36 PM
Thanks, this worked.
