AP1242 Software 12.4(10b)JA
Feb 4th, 2008
I have 36 of the ap1242ag access points right now. 6 of them have the 12.4(3G)JA1 software and the other 30 have the 12.4(10b)JA. On the 3G versions I could put in ip subnet-zero and that would show in the running config, but on the 10b version it lets me put it in but it does not show in the running config. I also was just putting in resource policy and it would show in the running config, but on the newer 10b version it will not let me enter it and it will not show. Are these problems, or does the newer version support tne ip subnet-zero version without programming or is it no longer avaialbe. What else is different?
klcoyne07 Tue, 02/05/2008 - 10:12
Thank you. Here is something else that is unusal. On the older version I setup local administration list and once I log on using the web browser I can see the services tab where I can change the clock and such. But on the new version as soon as I change from a global password to a local administration, I can no longer see the services, when I click on the tab it just comes up blank with a couple odd characters. I am assuming this is something with the new version that might be a bug.
