IP Phone power problem
Feb 4th, 2008
I have a 3750 POE. When i connect 7911 to it via patch panel it gets power, when i connect 7940 / 7960 with it through patch panel it doesnt get power while the same phones get power if i directly plug the phone into 3750. On console i am also gettinf following messages
ILPOWER-5-IEEE_DISCONNECT
Everthing was working fine before this
Any clue ?
Paolo Bevilacqua Mon, 02/04/2008 - 11:44
  • Hall of Fame,
    Founding Member
See below for meaning of message. I suggest thay you check with a cable tester that all wires in your cabling systems are correctly paired.
Error Message ILPOWER-5-IEEE_DISCONNECT: Interface [chars]: AC disconnect
Explanation This message means that the powered device is no longer connected to the switch or that the connected powered device is being powered by an external AC power source. No power is on the switch PoE port. [chars] is the interface.
Recommended Action No action is required.
munawar.zeeshan Mon, 02/04/2008 - 11:50
The wires are ok. Moreover everthing was working fine on these wires earlier.But they are still ok.
Paolo Bevilacqua Mon, 02/04/2008 - 11:57
  • Hall of Fame,
    Founding Member
Can you try rebooting the switch then ?
