VOIP over Long Range Ethernet
I have a 2950LRE switch connecting to 2 585 CPE devices. Since the 585s do not support vlans is there a certain way I should configure the Cisco phones, or the switch to where they will work? Also the switch does not support multiple VLANs on a single interface.
Thanks for any suggestions in advance.
Roger
Here is the config of the switch if it would help:
Building configuration...
Current configuration : 1772 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Botkins2950LRE
enable password 7 13065601085C
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
controller LongReachEthernet 0
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface LongReachEthernet0/1
cpe type CISCO585-LRE
rate selection profile lock
flowcontrol receive on
flowcontrol send on
interface LongReachEthernet0/2
flowcontrol send on
interface LongReachEthernet0/3
flowcontrol send on
interface LongReachEthernet0/4
flowcontrol send on
interface LongReachEthernet0/5
flowcontrol send on
interface LongReachEthernet0/6
flowcontrol send on
interface LongReachEthernet0/7
flowcontrol send on
interface LongReachEthernet0/8
flowcontrol send on
interface Vlan1
ip address 172.16.1.110 255.255.255.0
no ip route-cache
interface Vlan10
description Data
no ip address
no ip route-cache
shutdown
interface Vlan20
description Voice
no ip address
no ip route-cache
shutdown
ip http server
line con 0
login
line vty 0 4
login
line vty 5 15
password 7 08220D5D0A49
login
end
Botkins2950LRE#
paolo bevilacqua Mon, 02/04/2008 - 14:20
  • Hall of Fame,
    Founding Member
Do not worry about different vlans. If and only you experience voice quality issues during large data transfers, you will need to configure QoS somewhere.
paolo bevilacqua Wed, 02/06/2008 - 01:09
  • Hall of Fame,
    Founding Member
Yes, beside you have not other choice.
Please remember to rate useful posts using the scrollbox below!
