ASA - VPN Domain Name not given to clients
Feb 4th, 2008
I am setting up a new ASA 5510 with v8 software. I have L2TP-IPSec clients using the Microsoft Client to connect. Once connected the client receives an IP, DNS server and WINS servers but the Domain Name for the "Connection Specific DNS Suffix" is blank. How can I get the clients to pickup the dns suffix?
Also when I do an nslookup hostname, the response is coming from the DNS servers attached to my LAN Adapter, not the VPN Adapter.
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
wins-server value
dns-server value
vpn-tunnel-protocol IPSec l2tp-ipsec
ip-comp enable
split-tunnel-policy tunnelspecified
split-tunnel-network-list value DefaultRAGroup_splitTunnelAcl
intercept-dhcp enable
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol l2tp-ipsec webvpn
default-domain value
tunnel-group DefaultRAGroup general-attributes
address-pool DHCPRange2
authentication-server-group RaidiusServers
default-group-policy DefaultRAGroup
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
isakmp keepalive disable
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
no authentication ms-chap-v1
authentication ms-chap-v2
didyap Fri, 02/08/2008 - 13:59
One thing you may try on the ASA is to set the 2nd and 3rd DNS server to the same as the first one. If you are running a split tunnel the requests could go to the ISP's DNS servers. Another thing to try, for troubleshooting, would be to do a dedicated connection (no split tunnel) and see if that helps clear up any of the problems.
michael-ham Wed, 02/27/2008 - 10:55
I wasn't able to get the L2TP setup to work as I expected, it seems to me while it is supported the implementation of all the features is not as robust as just using the Cisco client. I had been using Microsoft RAS' implementation of L2TP and it worked great, but I wanted to get away from the server requirement. I was never able to get a Vista L2TP client to connect to the Cisco ASA.
I'm switching over to Cisco client with just IPSec.
