calling number doesnt appear over AS5300 GW
Feb 4th, 2008
Hello all,
i have AS5300, i connect it with PSTN through E1's, and i use the 1st timeslot for SS7 signaling and i use PGW 2200.
the PSTN user dial 0800 number and the call is forwarded to the IVR, everything is running smooth, and i can make calls, but for this call "0800" call, i cant see the calling number coming??
i made a debug for the ISDN, but the calling number line doesnt appear at all :S
attached is the configuration
thanks for the help
Overall Rating: 1 (1 ratings)
mohannadhabaq Sat, 02/09/2008 - 03:22
thanks for the reply
what does this bug means? is it related to calling number?
im using 12.4(10) does if downgraded/upgraded the IOS it will solve the problem? which version is most suitable
thanks
