a.rooprao Mon, 02/04/2008 - 16:58
Pls help.....
is there any alternate command to create sub interfaces with gig ports as it does not supports the command " int gig1/0/1.1 "
ilnaiduccna Mon, 02/04/2008 - 20:29
Hi roop,
enter the fallowing commands hope it will be clear you,
Switch-01#conf t
Switch-01#int GE0/1/2
Switch-01#description ******aaaaaaa******
Switch-01#switchport trunk encapsulation dot1q
Switch-01#switchport mode trunk
Naidu :-)
jorgenolla Mon, 02/04/2008 - 17:33
I don't think the 3750 support subinterfaces as per command:
int gi1/0/1.1
You would usually communicate with subinterfaces on a router with a trunk port and specific vlans for each broadcast domain. Otherwise known as Router-On-A-Stick.
Best Regards
jorgenolla Mon, 02/04/2008 - 17:41
Got some more information from the configuration guide, that confirms my suspicion.
From the configuration guide:
"A routed port behaves like a regular router interface, except that it does not support VLAN subinterfaces."
Here is the link for the configuration guide:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12244se/scg/swint.htm#wp1810955
Again your solution is Router-On-A-Stick, for inter-vlan communication, or SVIs.
Best Regards
