Please, help a noob (857 IPSEC)
kyle
I have an 857 Router at both sites,
I cant get the damn VPN to work, i try and debug, but no debug messages even come through, its like the crypto engine doesn't even try to connect?!?
This is my first encounter with cisco and the following has been pieced together off a few white papers.
What have I done wrong?
This is the config in the routers:-
X.X.X.X is the WAN IP address of the remote site.
version 12.3
hostname name
boot-start-marker
boot-end-marker
no aaa new-model
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.40.1 172.16.40.20
ip dhcp pool CUSTOMER-LAN
network 172.16.40.0 255.255.255.0
default-router 172.16.40.1
dns-server 203.50.2.71 139.130.4.4
ip cef
ip subnet-zero
ip cef
no ip domain lookup
crypto isakmp policy 10
encr aes 256
authentication pre-share
crypto isakmp key keyname address X.X.X.X
crypto ipsec transform-set aesset esp-aes 256 esp-sha-hmac
crypto map aesmap 10 ipsec-isakmp
set peer X.X.X.X
set transform-set aesset
match address acl_vpn
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 172.16.40.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxx@nnnn
ppp chap password 0 xxxx
crypto map aesmap
ip nat inside source list acl_nat interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 172.16.20.0 255.255.255.0 Dialer0
no ip http server
no ip http secure-server
ip access-list extended acl_nat
deny ip 172.16.40.0 0.0.0.255 172.16.20.0 0.0.0.255
permit ip 172.16.40.0 0.0.0.255 any
ip access-list extended acl_vpn
permit ip 172.16.40.0 0.0.0.255 172.16.20.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
johnd2310
Level 8
Level 8
hi,
What ios version are you running?
John
**Please rate posts you find helpful**
Site 1:
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(6)T9, RELEASE SOFTWARE (fc2)
Site 2:
The config you posted show it was created with ios 12.3 Check that some commands haven't been disabled during the save and reboot. Could also be that the routers have a problem with the high encryption you have chosen. Try with 3DES and progressively increase.
thanks
John
