642-642 (QOS) and 642-845 (ONT)
Feb 4th, 2008
These 2 exams are almost identical. Can anyone tell if taking QOS will be carried over in place of ONT and vice versa. That is if taking CCIP to CCNP (vice versa). I'm sure 642-901 will be carried over. Thanks
Overall Rating: 5 (2 ratings)
ccbootcamp Tue, 02/05/2008 - 03:57
  • Gold, 750 points or more
QOS and ONT are totally different exams. QOS is not a requirement for CCNP, but it IS a requirement for CCIP.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
toddlerdal Fri, 02/08/2008 - 08:13
I've taken both exams. There is some overlap, but ONT was a good intro into QoS. With some wireless thrown in.
For testing, you could easily sit through the QoS course and with a little extra material from Cisco on WCS, be covered for the ONT.
