02-04-2008 06:54 PM - edited 03-15-2019 08:37 AM
I've a 2811 router with one VIC2-2FXO card install, running c2800nm-advipservicesk9-mz.124-6.T6.bin IOS.
The configuration:
voice-port 0/1/0
echo-cancel coverage 24
no comfort-noise
connection plar 5028
dial-peer voice 3 pots
preference 1
destination-pattern .T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
no digit-strip
direct-inward-dial
port 0/1/0
forward-digits 0
dial-peer voice 2 voip
preference 1
session target ipv4:192.168.25.4
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
However, when I dial the POTS number assigned to the current analog line that is connected to this port 0/1/0, I got one ring and then a contious fast-busy tone. It should have rang to a particular extension, but it never dit.
I've verified that this analog line is capable of making inbound and outbound calls, and is working fine.
Can someone please help. Any input is greatly appreciated.
The debug voip ccapi inout is attached.
Thanks.
hieu
02-04-2008 10:38 PM
Your call is trying to go out the same DP 1.
Please configure destination-pattern like 5... on DP 2.
Also you don't need preference, progress_ind, and qos for media.
02-06-2008 10:13 AM
Thanks Paolo for your response. I'll try it out and update you on its status.
02-06-2008 10:48 AM
Paolo,
If I use "connection plar opx 4564", I could see that incoming call to the FXO port is connected, hear the ringing tone, but the ip phone is not ringing.
Thanks for your help.
02-06-2008 11:36 AM
Paolo,
02-06-2008 10:38 AM
I am having trouble of getting it to work still. It still didn't forward incoming call to extension 4564 as I'd like. Got fast busy signal.
Things that I've done:
a. removed the existing POTS line, and used a different POTS line conected to port 0/1/0. verified that the new POTS line is able to call in/out.
b. Disconnnect POTS line going into voice-port 0/1/1
c. Shutdown voice-port 0/1/1
d. Created dial-peer voice 6 pots - set similar setting as dial-peer 5 pots.
e. Did a shut/no shut on voice-port 0/1/0
This is the current config:
voice-port 0/1/0
no comfort-noise
connection plar 4564
voice-port 0/1/1
no comfort-noise
shutdown
description LINE NOT CONNECTED
dial-peer cor custom
dial-peer voice 5 pots
destination-pattern 911
direct-inward-dial
port 0/1/0
prefix 911
dial-peer voice 1 voip
session target ipv4:192.168.30.2
codec g711ulaw
preference 1
codec g711ulaw
dial-peer voice 8 pots
direct-inward-dial
port 0/1/0
dial-peer voice 10 pots
direct-inward-dial
port 0/1/1
destination-pattern 4564
direct-inward-dial
port 0/1/0
thanks!
02-06-2008 11:04 AM
Can you add timing hookflash-out 500 under your voiceport and see.
02-06-2008 01:17 PM
Thanks Rajesh for your response. I've added the command you mentioned, but it made no difference. Still got fast busy signal.
02-06-2008 10:40 AM
02-06-2008 01:20 PM
I got a hold of TAC...the problem that PLAR wasn't working correctly because the Call Manager rejected it due to improper setup or lack of the search base for the gateway. I'll get in touch with my colleages who handles the call manager to correct this issue.
Thanks everyone for your input.
hieu
