RME and NAMs
Answered Question
Feb 4th, 2008
I've added all of our NAM devices into the DCR and the inventory recognises them as WS-SVC-NAM-2 however it won't do a sync archive.
We are running RME 4.0.5 and CS 3.0.5.
The NAMS are running software ver:3.5(1)
and 3.4(1a).
I've also turned on exsession at the cmd line. The username and password are set, I have not set the enable. SNMP READ and READ WRITE are ok.??
Correct Answer by Joe Clarke about 9 years 3 months ago
What error do you get trying to sync archive on the 3.4 NAMs? If you perform a sniffer trace while syncing archive, what errors or problems do you see in the telnet session?
Note: NAMs running 3.5 will fail until you upgrade to RME 4.0.6 due to CSCsh27562. However, the 3.4 NAMs should be working.
Overall Rating: 4 (1 ratings)
Correct Answer
Joe Clarke Mon, 02/04/2008 - 20:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
