Cisco switch clustering
Feb 4th, 2008
Thanks in advance
what is actually a cisco switch clustering?it is a stack port activity or ethernet port activity?Swicth satcking and clustering are same word or differnert?
Paolo Bevilacqua Mon, 02/04/2008 - 23:23
Different. The clustering is used with the older 29xx models, and is not very effective in my opinion.
True stacking models are the 3750s.
san_dec21 Tue, 02/05/2008 - 01:05
hi,
thanks for help
but i want to know how to configure clustering?it's just a cable connection or any config is there?
aijaz802 Tue, 02/05/2008 - 02:06
Stacking and clustering are different.
A switch cluster is a set of up to 16 connected, cluster-capable Catalyst switches that are managed as a single entity. The switches in the cluster use the switch clustering technology so that you can configure and troubleshoot a group of different Catalyst desktop switch platforms through a single IP address.
Using switch clusters simplifies the management of multiple switches, regardless of their physical location and platform families.
Look at this... http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sec/configuration/guide/3750scg.html
Please rate if this helps....
Thanks..
